Will there ever be a backwards compatability guarantee?
Go, the programming language, has a remarkable backwards compatibility guarantee, in that the Go compiler will always compile any older Go program (within the same major version, which – currently – means anything written within the past 14 years). Does DeltaChat have any plans to implement any sort of backwards compatibility guarantee?
For instance, I have a perfectly good Pixel One (!!) running Ubuntu Touch. The phone is 10 years old and not only are no new OS releases being made, but often software versions are pretty old. I can’t use DeltaChat on it because I can’t link accounts because even 1 year is apparently “too old” for versions of DC to talk to each other.
10 years is a bit extreme, and I understand that during beta periods even 1 year may include breaking changes. Are there any plans to introduce any stability in the protocol to allow different versions to interoperate? I would think linking devices is something which hopefully wouldn’t have that much churn.
(unofficial answer, personal opinion):
Looking at the current practices, e.g. the upcoming drop of classic email (see Pinned messages, Liquid Glass, resilient decentralized onboarding and security-hardening efforts - Delta Chat) I wouldn’t expect the devs to make such guarantees, not within a year at least. If something is needed to be done but it breaks compatibility then it will be done. The current safety margin IMU is “a couple of months, so that everyone has time to upgrade”. But that I assume is not enough for you. Where compatibility can be kept it is of course kept (e.g. see test: test that MDN sent by core 2.23.0 can be received by the current core by link2xt · Pull Request #8774 · chatmail/core · GitHub).
Also note that there different all kinds of compatibility, and I’m not sure what you mean in your post.
You talked about backup compatibility, but there is also network compatibility of sender and receiver.
Here specifically I think you should be able to create a new profile on your old device, and then link the never devices to it. It’s that old devices can’t read the backups of new devices (and new devices are not smart enough to export backups in an old format).
Which UT version is running on this device?
