Saved messages appear out of order
If I select multiple messages in a chat and forward them to Saved Messages, they often appear out of order, sometimes almost completely random order. However if I forward messages to any other chat, the order of the messages is preserved.
Forwarding multiple messages to Saved Messages preserves the order of the messages, same as forwarding to any other chat.
Forwarding multiple messages to Saved Messages often mixes up the order of the messages.
i am currently checking that on iOS (added the multiple-save-option extra for testing :slight_smile: ) and indeed, it seems “forwarding messages” are sorted by timestamp while “saved messages” are sorted by the order they were selected
Let’s move this to GitHub issue: Multilpe saved messages should be ordered by timestamp · Issue #6862 · chatmail/core · GitHub
On Android I can’t even tell what it is currently using to sort the messages. It doesn’t appear to be timestamp or the order they were selected. Anyway great to see that you are addressing this :slight_smile:
