Own messages not mirrored to second device
I am using Desktop Vers. 2.65.0 and Android 2.67.0. I properly see messages from my partner on both devices, but see my own only on the device where I typed them. This leads to fragmented conversation threads when reading on the other device.
I have seen that I should disable the Delete from Server key, but this setting has gone in the version I am using.
I am using the testrun . org relay.
Make sure you have “Advanced” → “Multi-Device Mode” enabled on both devices.
Thank you for the hint, but yes it reads already “Mehrgerätemodus” i.e. multi-device on both the phone and the desktop app.
Was it working before and got broken after some update? How long have you been using DC on your devices?
Could you also check in the relay list if you have the same list of relays on both devices and if the address (and not just nine.testrun.org domain) is the same for both devices. Do you only have a single relay there?
