Option destktop client: behavior Enter key
Currently in the desktop client the message will sendet by pressing the enter key.
This way I very often I send a message by accident instead insert a new line.
A option for the enter key would be great:
  • send messeage
    or
  • new line
does shift+enter add a new line or it is impossible to start a new line???
if it works, IMO it is more easy to press shift+enter for new line and send with enter, than having to leave the keyboard to press a button with the mouse
Probably it works.
But I write with 10 fingers.
And so I very often I send messages by accident.
I think a global option would be nice.
Wow yes, a change is really needed here. IMO the established standard for desktop chat applications is to send messages via CTRL+Enter so I think that should really be the default for Delta Chat, too.
Meanwhile this option was added. @webratte can you mark this topic as solved?
