delta chat has the great and easy onboarding mechanism but it it centralized - it does just work over https://i.delta.chat - or is there on other way to add profiles/contacts without the https://i.delta.chat links ?
You can read how invite links work at GitHub - deltachat/invite: Invite links for Delta Chat · GitHub
Delta Chat handles the links internally and does not depend on i.delta.chat website to be up.
https://i.delta.chat is a fallback for the case when user does not have Delta Chat installed, telling to install Delta Chat and using the link inside the app. No data about the contact is sent to i.delta.chat even when you open the link in a browser.
I have previously wrote a longer post at
You can use vCards for this. Send a contact as an attachment (you can send contact “Me” to self as well), then export it, then send it any way you like.
Ok Thanks - but i still do not understand how to make new contact without i.delta.chat
How does this work in detail?
vCard contains the contact name, OpenPGP key, avatar and so on. This is all you need to write a message to the contact.
how to generate a vCard from within DC and how to import a vCard from within DC
Click “attach” button, select “Contact”:
Select the contact that you want to send. For the contact “Me”, scroll to the very bottom:
Contact gets attached to the message, send it:
If you want to transfer it outside Delta Chat, click “Export”:
You can transfer the file however you want. -
To add the contact, click on the message with the attachment.
See also related proposal to make it easier:
super - . great it works with vCards -
thanks for that Workaround… and yes it would be nice if it would be more easy to do
Export and Import of vCards should be offered by placed buttons in menus where they are easily found.
Not sure whether you went through all the linked threads, but just so it is also mentioned here, you can equivalently add contacts using openpgp4fpr links (and its QR code form) without spelling out https://i.delta.chat. In none of the mentioned combinations would a centralized service be contacted - invitations are processed between the DC clients of the two peers involved directly. You would then share a link such as the following with your friend:
openpgp4fpr:A11808CEE7890F00B54EB64183C1FA40200635D5#a=chatbot%40testrun.org&n=Mia&i=1uiiAtibina&s=iyHlIA_MABH
