Need help with audio calls [microphone & camera access]
:telephone_receiver: Incoming call (with user prompt) with offer:
SDP Call Information Summary
:large_blue_diamond: Session Information:
Version: 0
Session ID: 2710654388249708919
Origin Address: 127.0.0.1
:globe_with_meridians: Network Connectivity (ICE Candidates):
:house: Local Network (Host): 6 candidate(s)
β€’ 10.8.1.20:33725 (UDP)
β€’ 127.0.0.1:49437 (UDP)
β€’ ::1:46740 (UDP)
β€’ 26.132.0.95:9 (TCP)
β€’ 127.0.0.1:35935 (TCP)
β€’ ::1:58109 (TCP)
:globe_showing_europe_africa: Public IP (STUN): 1 candidate(s)
β€’ 146.103.42.67:33725 (UDP)
:counterclockwise_arrows_button: TURN Relay: 1 candidate(s)
β€’ 46.224.39.230:58882 (UDP)
:bar_chart: Connection Assessment:
:white_check_mark: Excellent: All connection types available
:movie_camera: Media Streams:
:speaker_high_volume: AUDIO:
Port: 58882
Protocol: UDP/TLS/RTP/SAVPF
Connection: 46.224.39.230
Direction: Bidirectional (send & receive)
:video_camera: VIDEO:
Port: Dynamic (9 = placeholder)
Connection: 0.0.0.0
:bar_chart: APPLICATION:
Protocol: UDP/DTLS/SCTP
Connection: 0.0.0.0
:musical_note: Audio Codecs:
β€’ opus (High Quality): 48000Hz, 2 channel(s)
β€’ red: 48000Hz, 2 channel(s)
β€’ G722 (Good Quality): 8000Hz, 1 channel(s)
β€’ PCMU (Basic Quality): 8000Hz, 1 channel(s)
β€’ PCMA (Basic Quality): 8000Hz, 1 channel(s)
β€’ CN: 8000Hz, 1 channel(s)
β€’ telephone-event: 48000Hz, 1 channel(s)
β€’ telephone-event: 8000Hz, 1 channel(s)
:film_projector: Video Codecs:
β€’ VP8 (WebRTC Standard): 90000Hz
β€’ rtx: 90000Hz
β€’ VP9 (Efficient): 90000Hz
β€’ rtx: 90000Hz
β€’ H264 (Compatible): 90000Hz
β€’ rtx: 90000Hz
β€’ H265: 90000Hz
β€’ rtx: 90000Hz
β€’ red: 90000Hz
β€’ rtx: 90000Hz
β€’ ulpfec: 90000Hz
:locked: Security:
DTLS Fingerprint: SHA-256
20:4B:C0:86:47:1B:DB:C5:27:8F:36:AE:66:65:4C:B3:56:B0:0F:97:47:09:03:0C:A7:3D:EE:BA:F7:DA:25:63
:key: ICE Authentication:
Username Fragment: uS3q
Password: [PRESENT]
Failed to getUserMedia with video, will try just audio
NotReadableError: Could not start audio source
Accept call prompt resolved: accepted
incoming media not playing, will .play() it
incStream.videoTracks() muted states:
Array [true]
incoming media is playing
What OS are you on? Did you give Delta Chat the permission to use the camera?
Windows 11
there were no requests for access to the camera
Yes, there is no permission pop-up on Windows, but I believe there is still permission control for it in settings. Please check that.
Also check if the Delta Chat’s QR scanner works.
The DeltaChat app is missing from the camera and microphone access settings.
Does sending an audio message also not work? Did you manage to fix it somehow? Are there other Windows 11 users where it is working?
I am using an /e/os with Delta Chat and making calls to another /e/os or android (video and audio) works fine. However, when I try to make a video call to an iPhone with Delta Chat installed, the audio does not come through the speaker, in fact, the whole speaker/earpiece selection button seems not to exist on the iPhone version of DeltaChat? Is this me (iPhone 12), or have other people also noticed this?
I suggest opening a separate issue about this with more details and logs possibly.
OK, thank you. I will do this as soon as I have access to the logs of both my phone and the iPhone.
Where / how do I get the logs of a call?
Settings :gear: β†’ Advanced β†’ View Log
It has been a few months since I posted the initial post about the mic and camera access on MacOS and iOS. Many thanks to those who looked into this issues, it seems to have been solved, almost. I can now indeed make a video call to an iOS system with camera on and mic. But, somehow the sound on the iPhone is very very low. All settings are normal (volume levels, audio-input levels) and work fine with between-Android phones. When this is solved, I can finally ditch whatsapp for good! Thanks everyone and sorry I cannot help on the technical side of this problem, I wish I had the knowledge.
