Maltese translation
Hi,
Can you please add the Maltese (mt-MT) language to both the website and the app in the translation software?
I’ll take care of the translation.
i added mt to both, app and website.
if you give me your transifex handle, i can make you a translator.
i’d start translating the app, then the website’s help (which also goes to the app) and then the remaining,
we check for complete app translations on a regular base, however, you can also ping me.
thanks! i got the request and accepted, you should be able to translate to Maltese now
Thank you :slight_smile: May I ask you for a tiny change when it comes to variables? Maltese doesn’t count 1. So [var] min (for count 1) is incorrect. The system won’t let me save the translation with the missing variable for 1.
i turned “Variable substitution specifiers (like “%s”) are preserved in the translations” from an error into a warning, so you should be able to process.
however, for nearly all other things the error is fine. so i would turn it back in some days, to not degrade translations in general
