v1.3.0
I did an iOS backup export ant tried to load it into the desktop.
This works and I see all the messages from iOS.
When delta chat reads the .bak file, it should work normally
with the email settings from iOS.
The email account settings are wrong.
There is some default setting of the SMTP user that seems to fill in
the IMAP user name, which is wrong in my case:
I think the problem is simply that this default is used, although the
settings come from the working iOS installation, and there is no
way to enter “no user” by leaving the field blank, because that
wrong default is always applied.
Reproduction
You need an email account that has an IMAP user name, but no SMTP
user name. This is so at stackless.com.
Set up delta chat on iOS and export a backup. Restore that backup
on the desktop. You will see a red message that the connection failed.
You cannot fix that because there is no way to enter “no user” into SMTP
if you have one in IMAP.
Cheers & greetings to HPK
i don’t understand – how can you get an SMTP connection to
