How-to: Delta Chat interoperability with other ENCRYPTED email clients
Situation: you or a friend is using ProtonMail, Mutt, K9-Mail, Thunderbird or other email client with encryption support, the other is using Delta Chat and you want to chat.
From now on it will be assumed you are the one using Delta Chat while the other peer is using the classic email app.
In Delta Chat you can export your public key as vcard, you then need to import that key from that vcard in the other email clients that support encryption, if the other person share their key via another channel, you could even convert their key (.asc file) to a vcard and import it in your delta chat so you can immediately send encrypted to that person and they can send encrypted to you with the key you shared with them, I think this will work even without autocrypt at all, so the steps are:
  1. Share your public key with your peer via another communication medium
    1. go to Saved Messages
    2. click attackment button
    3. select the contact button to attack contact
    4. scroll to the bottom of the contact list that appear and select the last item that is your own contact
    5. send the attached contact in the Saved Messages chat
    6. select the message you just sent with your contact info, select “export attachment” this will export a vcard file
    7. share the vcard file with your friend
    8. if your friend doesn’t have a client that can import encryption keys from vcard (ex. protonmail can) then you will need to first edit the vcard in a text editor and extract the key and convert it to an .asc file and share that .asc file with your friend, your key is URL-encoded (base64) in a KEY: field.
  2. In another communication channel, ask your friend to send you their public key (.asc file or .vcard in the case of ProtonMail)
    1. if they sent you a .asc file you will need to use an in-chat tool we have called “.asc to VCard” see it here: webxdc apps with this tool you can convert .asc to vcard that you can import in your delta chat
    2. send the received .vcard file in your “Saved Messages” chat and click it, this will import the key of your contact
    3. now you can start sending encrypted messages to your contact!
ALTERNATIVE:
there is also a Delta Chat bot that allows you to query WKD, click here to get in contact with the bot
if your peer have their key published in WKD, you can just send their email address to the bot and the bot will answer with the peer’s contact vcard which you can click to start sending messages to them!
I think Protonmail does not support Autocrypt?
Related:
but it supports manually importing/exporting keys to vcard that is what is being explained here, they can manually import the key you share with them then they can encrypt to you
Yes, I wasn’t thinking, as long as you are not using a Chatmail account that should work. With Chatmail you’d obvs get a “Encryption Needed: Invalid Unencrypted Mail”.
The related link I posted was one using a Chatmail account in a non-DC client, which coloured my thinking.
