I’m used to install Android apps pulling from their repo’s releases pages through Obtainium.
On my way installing DeltaChat ( and it also goes for ArcaneChat, not sure what i was smoking, even though ArcaneChat “get apk” icon link to the gplay flavor, the releases include all variants), the release page only has the gplay flavor, which is built with USE_PLAY_SERVICES= true (as shown here: deltachat/deltachat-android/blob/281e145d5b4d8a8a0d47faba61f3c71cad7c6228/build.gradle#L129)
Is there any reason the foss flavor isn’t also available alongside the gplay one?
I might be mistaken, but wouldn’t users requiring the Play Services download DeltaChat using the Play Store anyway? What is the incentive for serving this flavor on github?
most users have gplay services, and expect things like notifications to work, even if they install from github or obtainium
offering several flavors would cause confusion and extra maintenance and support effort. people would need a deeper understanding of the system just to install, and they could end up updating with a different flavor, which can fail or lose features.
so the gplay flavor is the best default for most users, even on devices without gplay services (e.g, huawei)
for users having additional needs, there is the f-droid build. if you want to use obtainium, i am pretty sure, you can configure it using f-droid as well - if you manage to, feel free to post a link here
note that f-droid builds are signed differently, switching between f-droid and other sources requires backup export/import
It’s a fair point overall, and I get your motivations.
But I’d argue, if a user is competent enough to download and install an apk (even more so after the process imposed by Google to install “untrusted” apps), I would expect them to be able to differentiate *gplay.apk from *foss.apk.
I see the apk link in on your download page points to https://download.delta.chat/android/deltachat-gplay-release-2.64.0.apk. Would you consider serving the Foss version on your download page alongside the alternatives? Obviouly with a disclamer “foss version not for Gplay users”.
Fdroid is often criticised for their security approach, build SDK level, build dependencies, etc… Points I agree with
so for you, foss-from-f-droid via obtainium is not an option for security reasons? since that should otherwise work
sure, we consider a lot maybe something to discuss in the team at some point.
but don’t hold your breathe right now. if i recall correctly, last time this was discussed, the outcome was not to offer different flavors, for reasons mentioned above. and i do not see many massive new points. but let’s see, it is not me alone deciding that, if security of f-droid has degraded massively, that might be a point
It sure would work and most probably woundn’t be a dealbreaker for most of your userbase.
But avoid using F-Droid for the time being. If they were to address some of the security aspect of their workflow I would consider moving back to it, after all it is still one of the most popular platform for open source application to gain visibility. But part of those issues come from their philosophy and inclusivity.
Building myself it is then!
Thank you for taking the time, and for the warm welcome
Looking forward to see what the fuss is all about
Edit:
Just edited the first post, ArcaneChat does in fact have releases for all flavors/couple of architecture
