Device Contacts option missing w/ Chatmail
Delta Chat version 1.46.2
Well if you are using a classic email account, there is an option in the settings that enables/disables Deltachat to look at the device’s contacts and make people’s names and photos inside Deltachat to match those in the system contacts.
If you are using a chatmail account, the option is gone. I wonder whether there is a reason for this.
  1. …n/a
  2. …
n/a
Debug logs
Logs
the reason is that with chatmail, you can only write encrypted messages - which is doable as described eg. at Instant Onboarding and Instant Message Delivery - Delta Chat
offering random addresses from the addressbook, that probably do not use deltachat, seemed not to be helpful - at least on the first iteration, we did not see a usecase and removed the option for chatmail at hide IMAP folder options on chatmail by r10s · Pull Request #3050 · deltachat/deltachat-android · GitHub
to be clear: the option is still available when using a classic email address as a profile.
