Delta Chat Android application energy [forced background connection battery drain]
Delta Chat 2.43.0 on Android
Energy consumption on Telegram levels ~7%
Energy consumption 70%
  1. Use it for a day or two
Debug logs
deltachat-log-20260323-005506.txt (175.4 KB)
In the notification settings, disable - Forced connection in the background…
notifications already work, but this option consumes the battery very much
I have the same problem: high battery drain when I’m on a call. After just two minutes, the system showed about 70% battery usage. In comparison, with Conversations (XMPP), the system showed about 50% battery usage after a one-hour call.
ich hab das gleiche Problem, einen hohen Akkuverbrauch wenn ich telefoniere. Nach 2 Minuten hat das System ca. 70% Akkuverbrauch angezeigt. Im Vergleich zu Conversations (xmpp) hat das System bei einen einstündigen Gespräch ca. 50% angezeigt.
Yea, but it won’t wake up my phone on calls when I’m not using ‘Forced connection in the background’. Is there a way around that? It really looks like it’s heavier on battery compared to Conversations (which does wake up my phone on calls) when using ‘Forced connection in the background’.
Should I ask the developers? :thinking:
