Amazon Appstore
I’m posting this here, though I’m not sure if it’s the best place to post:
I have an Amazon Kindle Fire HD 8, already fairly outdated but appears to be able to run Delta Chat well. The problem I ran into is that while side-loading the APK was simple and straightforward, making it work with Amazon Kids was an entirely different matter. Amazon Kids does pretty much whatever it can to prevent non-Amazon apps from being able to run, and if you try to select a specific app (e.g. Delta Chat) to be available in Amazon Kids, instead of using the APK already on the device, it attempts to download the app from the Amazon Appstore only. I ended up with this bizarre situation where the Kids profile downloaded and installed a very outdated version of Delta Chat that no longer works.
Personally, I managed to work around the issue by forcing an upgrade to the Amazon version of the app using adb, but it’s not ideal. Amazon’s ecosystem is so locked down that I’d like to propose uploading Delta Chat to the Amazon Appstore in addition to the other repositories. Unfortunately, a lot of people have Fire tablets (they are cheap), and having DC available for these devices would reach a lot of people and be particularly helpful to families with children who need parental controls for safety.
hi @Ben - first of all, welcome aboard!
in fact, we were doing this for some years, until 2025.
then Amazon rejected updates for weird reasons, we did not manage to speak to a human, and we finally gave up and deleted the version from the app store.
unfortunately, it was not really deleted, it seems. would be better to have no version in the appstore than an outdated.
i just login and to uploaded an update, as removal did not work. let’s see, maybe it works again. we did it in the past as it was easy, and unlocks some usecases, as you pointed out. in general, amazon appstore did not cause any issues all the years, until it did :slight_smile:
we manage to update there - actually i tried to “delete harder”, but failed - probably i need to try harder" :slight_smile:
anyways, amazon should have version 2.64 now and we’re considering to deploy there at least every now and then again:
