Yandex (corporate mail whih login type xxx@xxx.com) dont work login not corporate xxx - work
Please help
Yandex
(corporate mail with login type xxx@xxx.com) dont work login not corporate xxx - works
idea nice but not works
what do you mean with “corporate mail”?
in general, yandex.com has worked in the past.
however, we did implemented oauth2 also for yandex.com, see https://delta.chat/en/2019-02-20-gplay-oauth2 , so using this provider should be smoother for the upcoming releases and won’t require any special settings.
corporate mail – https://connect.yandex.com/pdd/?ncrnd=1672
deltachat remove symbols after @ in login
then login xxxx@yyyy.com transform into xxxx
and bundle login / password is wrong
okay - seems to be sth. as “gapps for your domain” or so :slight_smile: – oauth2 won’t help if the domain is not yandex.com|ru|ua
delta chat tries first to login with user@example.org only if this failed, a second attempt is done with only the part before the @-sign - user in this case.
in any case, you can also try to enter completely different credentials for the server by using “advanced”.
its dont work.
what didn’t worked??? did you tried to expand the advanced options and did you entered the right imap and smtp users, etc. ???
