Web client possible?
I believe this would be possible in this scenario.
  1. We host a “web-client-delta-chat” page written with
    html, css, js on IPFS.
  2. Any user who has a browser like “google chrome”, “brave browser”, “librewolf” etc… with plugin: “ipfs” - renders the content of the web-client-delta-chat page.
  3. The rendered page communicates with the ajax api in javascript.
  4. There is a program installed on the user’s pc called “api-core.rust”. That program is installed or can be installed from the apple-store, playstore, etc.
Hello :wave:,
If you have to install a program anyway, why not DC Desktop?
What would be the advantage of using DC in the browser?
Hi Raiden.
There are easy things that work without wasting RAM. I like everything on the web because it doesn’t require a lot of processing.
I’m trying to help this topic with ipfs. Please see this: https://docs.ipfs.tech/how-to/websites-on-ipfs/single-page-website/#install-ipfs-desktop. There are several advantages, I will list 8 advantages:
performance:
  • the main advantage of this idea is that you don’t need to use electron-js. It is a performative solution, because messages could load a lot faster with “ajax”&“api”&“restfull”. And because static files like js, css, html are loaded faster with cdn network. And because: messages are rendered by the device itself.
economy
  • another advantage is that it would not need a server connected 24 hours a day, 7 days a week or 365 days a day to work. This is because the delta-chat version is in ipfs, which is a decentralized protocol, p2p.
ease of use
  • another advantage is that you could install the email client on your mobile phone which could automatically sync the messages to your desktop. This is interesting if you want to look at a bigger screen.
  • you don’t need to configure or start any servers.
  • if you want to use delta-chat on your desktop without having it installed then one option would be to use delta-chat-web or delta-chat-mobile
security, privacy, anonymity
  • this option is interesting because it works completely offline, locally. There would be no vulnerability or direct attack on the server. It happens - because the frontend page is in ipfs, but the backend is run by android or any mobile version.
user experience
  • the user accesses a website. And your messages are synced locally by mobile
independence
  • you create the graphical interface with html, css, js and host it in ipfs. The mobile renders the page in ipfs. And uses an internal delta-chat to an desktop environment.
What do you think of this idea?
There are several interesting electron-js alternatives here. For example,
In summary, we have the following options:
1. flutter for web/mobile/desktop or
the advantage of flutter is that flutter is used to build cross-platform applications. Because it operates on a single codebase and renders native code on each platform, Flutter engineers can build native-like apps faster and with lower development costs. Flutter apps are compatible with iOS, Android, Windows, macOS and other platforms.
the downsides of Flutter is that it is a relatively new framework and may not have the same level of community support as React Native. This can make it harder for startups to find resources and support for their development projects.
another disadvantage is that you would have to change the frontend or backend or full-stack source code to flutter, which can be bad, because while a newer version is not made, certain features are left out.
ps: Of course users can choose to have an older version with less features compared to the development version.
2. tauri-js or nwjs for desktop or
the advantage of tauri-js and nw-js is that they are alternatives that consume less ram than electron-js.
tauri-js works with webview whereas nw-js will open the given entry point in a browser window. In Electron, the entry point is always a JavaScript script. Instead of providing a URL directly, you manually create a browser window and load an HTML file using the API.
the downside of nw-js, tauri-js is that they take browser resources to work. Despite being alternatives to the electron, they work in a similar way with technically very small differences.
3. self-hosted or
the only advantage of this type of architecture is if you have a personal homeserver or have money to keep the infrastructure of a local server running.
The downside of self-hosted architecture is that a server is required to run 24 hours a day, 7 days a week, 365 days a year. For most users this option is bad, because you have to have a certain level of computer knowledge to set up or manage self-hosted.
4. delta-chat as a browser add-on or
the disadvantage of this idea is that webassembly does not have the necessary resources to make this option interesting
5. only serverless/unhosted for desktop: ipfs(frontend), backend(mobile) for desktop - the proposal you suggest. and api/restful/ajax written in rust(in mobile).
As I understand it there would just be a mobile compiled UI and the web interface would be rendered by the browser into an ipfs address. The user would only have to have a dns address pointed to ipfs or even the ipfs address to access directly in the browser.
The advantage of this software architecture is that you don’t need to install anything on your computer. You would have to install only the mobile version to send or receive locally and offline synced email messages with web or desktop.
Another advantage of this idea is that you could have just one compiled version and another version just rendered, rendered by the browser from an ipfs address or custom dns address to ipfs.
In theory this architecture would be faster, because the entire frontend part runs separately from the backend part. The backend part, in turn, depends exclusively on the user’s cell phone hardware to function. Another advantage is that even if the user’s hardware is old, this will still work with certain performance and speed.
A final advantage is that each user can create custom instances of the delta-chat frontend on different types of networks, such as: i2p, tor(onion), hypercore, dat, ips, freenet, etc., to guarantee certain anonymity, security, control or privacy.
The downside is that whenever the graphical interface changes, a new ipfs address must be generated and must be associated or not with the custom dns, if that option is interesting and preferable. But this would happen only through the web version and not through the mobile version. Because the web version is different from the mobile version.
The final downside is that the web and mobile versions are different. As they are different versions, the code of the versions is also different.
Another disadvantage is that someone would have to be responsible for hosting the web version on some network protocol, server.
Notes
  • As we can see there are 5 solutions for delta-chat to be faster or more performant, or even general solutions for the desktop, mobile or web version.
  • In my humble opinion, the web option with serverless/unhosted would be better. Because the user accesses the site and uses delta-chat. It would be an experience equal to solutions like Spike, Gmail, Telegram-web, Whatsapp, Spark-mail etc.
Some of the topics and posts are already sparsely or transitively linked, but let me list here together all posts related to shipping static web client apps (WebAssembly, wasm, Emscripten, Rust, TCP/IP, proxy, gateway, compile, WebSocket, JMAP, JavaScript, API):
Would a local webclient circumvent the Russiaan whitelisting censorship of mailservers?
In some countries, it would make circumvention easier, in others, harder. For example, while most websites were blocked in Cuba, you could still use Delta Chat over IMAP to communicate via the national email provider.
In my opinion, it adds to a well-rounded ecosystem if a given messenger supports as many ways to deploy and as many workarounds as possible.
In the specific case you ask, you could already tunnel TCP (IMAP & SMTP) inside TLS/HTTPS/DNS with some hacks and boxes at the right places or use Psiphon. This would be a topic for another conversation, though.
