V 2.64 is still not avalible on f-droid?
the 2.64 version is available on github releases, but i still can’ t find its update on f-droid, did u forget that?
F-droid takes a little bit more time to be published, the two releases before took 2 and 3 days to be published on f-droid after the github release, maybe this one is taking a little bit longer.
I forgot to mention, if you like to update ASAP I recomend to use ObtainX or Obtanium (I’ve used both, now I’m using the first one, It made me easier to add new apps) this software let you follow the github repositories being faster to get every update.
thanks for introducing! the obtain looks good, but, first, the deltachat in github releases is different from f-droid version! if u have a try, you will find that you can install two same Delta Chat apps, one is from github/googleplay, the other is from f-droid…
在 2026-10-31 00:20:24,duub delta-forum@testrun.org 写道:
I don’t deeply understand how it works but I’ve read something about f-droid do their own compiling stuff and sign the apps with their own key, maybe is that
yes u r right, the F-Droid version of the same app differs from versions obtained from other app sources(like github/googleplay) and i want to test my deltachat, u can add & chat with me if u like​:waving_hand: Message privately on Delta Chat
在 2026-10-31 17:26:49,duub delta-forum@testrun.org 写道:
If you’re unaware, there’s an endpoint (and even an Android app) to monitor the F-Droid build queue located here: https://monitor.f-droid.org/builds
Fun trivia, if you follow the links towards the bottom to look at the “checkupdates” pipeline, the tasks almost always fail because it takes longer than 3 hours to run (so technically it’s always running). It also appears the build order (generically, there are exceptions) is reverse alphabetical of the internal package name; take a look to the currently running build cycle and you’ll see the pattern in the names, refresh, look again, etc.
wow so interesting, i already get the new version, my mirror repo in china is a little delay…
在 2026-10-31 20:43:10,“punkero.org” delta-forum@testrun.org 写道:
