I wish that in DC I can have streams for different topics inside a group.
I want to avoid to have a very long chat history or to create several very similar groups because another topic needs to be discussed as it makes the chat list very long. With some kind of hierarchy one can quicker navigate to the things relevant.
I really like how Zulip organises conversations.
On Zulip it is very easy to structure topics in different streams, so one does not get lost if a lot of messages comes in or different topics need to be discussed. (also new members have optionally the possibility to read the history of a stream in a very clear form).
I also really dig zulip, and i think that delta could improve on the concepts of streams and tags if we think it through.
Discord also has a thread feature, but i am not so crazy about the details of the implementation.
If we start with adding the possibility to tag messages, then i think that we could use tags to organize the overall display hierarchy without enforcing an actual hierarchy.
Technically it should be quite doable - perhaps via a similar message mechanism as the message2.disposition-notification.
I recently discovered the “Space” Feature of Matrix/Element. It allows one to organise the appearance of groups individually (and this structure is shareable/proposable , in case the other members wants to adapt to it.)
That is also a quite nice feature.
@Jikstra (Jikstra) Talking about the threaded mode, I think we all want it, the big question is how. What is your opinion on how to do it? The questions that arised before for us where: reddit/mailinglist like threading or only 2 level (like telegram/zulip). Also, should replies get hidden from the main “stream” or displayed? When you switch to the threaded view, shall it switch to a specific view that only displays this stream/thread or shall it show arrow buttons to jump to the previous/next reply? from github#2538
amazing questions… some of my thoughts above… more tomorrow…
So a bit of a vision for flexible thread rendering:
No hard coded hierarchy
Configurable independently for each client and each conversation
Options for threading:
time based like it is now
reply based - most recent reply in a thread is rendered at the bottom, with a disclosure arrow to expand the earlier messages from the thread upwards
tag based - choose top level and sub level tags to use as rendering groupings (advantage over reply based is that it can be organized later by adding tags)
if it isn’t too complex, it may be cool to support a tag as a top level thread organizer and then render in reply mode within each tag group
I too am wanting threading in groups. This would allow a substantial group to discuss multiple topics without creating new groups or all the info being lost in one long list of multiple discussions.
Delta is amazing already … but could replace almost all communication services (forums, blogs, Slack, Telegram, etc.) with just a few additions. Grouping groups and threading are two of the needed functions at the top of my list.
Threads don’t really fit in a chat group in my opinion, but rather in a forum like this.
I’m not a developer but maybe it’s possible to develop a forum webxdc app that will expand groups if needed. The corkboard app goes a bit in that direction.
Yeah, people love the idea of threads in messages. In reality, nobody uses threads “correctly” (people reply outside of them). And that “incorrect” use ends up being worse than if you never had threads at all.
I think now in times of AI and bots there is another usecase emerging. Having a thread feature in chats would allow bots to integrate LLM chats into apps like delta by having subchats - so basically threads - within a chat.
Yet another usecase that I see is something like “team bot” where multiple incoming chats are muxed into a single chat (if I understand correctly). Threads would allow keeping this clean. On broader terms this could also be interesting for bridges in general.
In the meantime I have changed my opinion and find threads like in Telegram very useful. By this I mean the display of all replies to a message. I think this could also make sense in 1:1 chats.
Threads in group chats are an anti-pattern in my opinion. @Low brought up the issue of inevitable inconsistent use of threads. I would add that the apparent benefits for future review are a mixed blessing, because group chats encourage things like jokes and real-time coordination which are of little interest to future readers. Better not to expect people to read logs of synchronous chats to “get up to speed.”
A usable UX for threaded messages already exists in forums and mailing lists, where threads have titles and every message belongs to a thread. Compared to these asynchronous forms, threaded group chats make people spend more time reading noise and less time thinking before they post. This is great for engagement metrics, but a net loss for users.
I can see a use for an asynchronous mailing list/forum platform with Delta Chat’s security and decentralization properties, but it wouldn’t make sense as part of the main Delta Chat client.
I think Apple Messages does it best now. Have you used it before?
Basically you can reply to messages, right? Well there’s a simple area to tap where you can view all messages that replied in a chain. It’s an optional view layer over top of the simple reply primitive. So it doesn’t add another primitive.
I implemented it in my custom chatmail client and it works great.
I have not used Apple Messages, but that sounds more reasonable than the way it works in e.g. Slack, where replies show up only under the parent post.
But this still has the problem where the user has to take the initiative to sent a message as a reply, so there are often messages relevant to a thread that were not sent as replies. The best UX for threads is not what Apple Messages does, but something like forums and mailing lists where every message belongs to a thread with a name and there is no ambiguity about whether a message addressing another message should be sent as a reply.
You should really experience it to see how nice the UX is. I have no complaints about how apple messages does it, and we both seem to be annoyed by similar things.
So what happens when someone replies to an old message, then there is a real-time discussion on the topic where people don’t bother to use the reply feature for every message?
No… Group chats with threading are the exact opposite, where there is ambiguity about whether to use the reply feature or just send the message like normal. Am I making sense?
Yeah usually someone replies and others just send messages normally. But it’s oddly fine. The “threads” are not real threads. They are very light in terms of UX. It’s just replying to messages, which delta chat already has. The “threads” are an aggregation of replies
I know what you mean. The joke was that a normal group chat with no “thread” primitive is the same as a forum lol.
