Please add to the settings:
Outgoing Media Quality - Maximum (Original)
I know that I can send through a “File”, but sometimes you accidentally make a mistake or forget, Or the person does not understand well and sends incorrectly. Otherwise, I would have set it up once and everything was fine. And the Internet speed is good now.
we’re not so much about adding options, that user need to tweak and understand.
however, we improved the image quality a lot recently - and made that the new default
still, if you really want to attach images as original, that will stay a per-image action that should be used rarely. we do not want to have that as a global setting. it is not only a decision of the sender, but also affects all receiver and relays. and the impact is not clear to many user just reading “high quality”
