Testrun.org refusing port 25 connections, can't use xstore@testrun.org
Tried to send a ‘Hi’ to xstore@testrun.org for the first time tonight, but the email can’t get through:
May 27 01:59:43 box6 postfix/smtp[14974]: connect to testrun.org[2a00:f820:417:0:5:1:76:52]:25: Connection refused
May 27 01:59:43 box6 postfix/smtp[14974]: connect to testrun.org[5.1.76.52]:25: Connection refused
May 27 01:59:43 box6 postfix/smtp[14974]: 090DB1E1A1: to=xstore@testrun.org, relay=none, delay=1.4, delays=0.09/0.02/1.3/0, dsn=4.4.1, status=deferred (connect to testrun.org[5.1.76.52]:25: Connection refused)
Did I just catch it at a bad time? (testing from another server on another network didn’t have any better luck)
Could you test again? It was not working for me also for other ports around this time, guess it was some maintenance, VM restarting etc. Now seems to work again.
I think about an hour after I posted this things were working - received the replies I was expecting, etc.
