My provider has limited the number of postsI can send per minute. This means that the quick question-answer sequence is no longer possible. Do you know this problem too?
Hier ist eine Liste mit den Sendelimiten von Mail/Providern:
Here is a list of the sending limits:
Yes, and that’s why you need to choose a good provider.
With most of the providers I have tried I have no problems. There is only one provider that gives me problems and blocks me.
Sometimes it helps writing to support and asking to remove the limit for your mailbox.
