Can I send a message from my android apptication to myself to view this message by a IMAP-client (for example Gmail)? Now I send a message to myself and I see one in the folder DeltaChat but I can not read this message beacause the message contaits only two unreadable files.
Hi and welcome
Of course.
This message is encrypted with your own PGP key.
So you need a way to decrypt this message.
E.G. by using a mail client wich supports autocrypt or if you like to read it in your browser you could also use mailvelope.
Saludos, cuando envĂes el mensage desactiva la encriptacion para que te llegue normal, despuĂ©s vuelves a activarlo. Y podrás leer tu mensage en tu otro cliente sin ploblemas.
what @agutierrez said is that you could also go to advanced settings and disable encryption so your emails will be sent unencrypted and readable with your email client
