Removing features from Delta Chat
  1. What happened to “export private key” and why extracting blob from SQLite backup is the only way?
  2. What happened to “show classic emails: always/only from contacts/chats only”?
  3. Why does DC pollute my inbox by not moving the messages into DeltaChat folder anymore?
  4. Why can’t I send a plaintext email, if besides my email account there are extra chatmail relays in my set?
No. 2 is the actual complain from non-tech-savies I have been installing DC for – since an update, they started seeing SPAM emails, even though earlier DC was configured to ignore emails from non-contacts.
I hope it’s just the developer team rarely testing with non-chatmail accounts, because it feels like making DC as uncomfortable to use with traditional e-mail accounts as possible, then get rid of it.
  • using “Classic Email as Relay” is supported, as long as the classic account is used exclusively for Delta Chat or other chatmail clients
  • using the same account between Delta Chat and other non-chatmail clients is not supported since quite some years.
as a consequence, features for unsupported usecases are removed. this is needed to be able to implement the multi-relay approach and many other recent developments. also, we remove features that are not understandable for the many. we avoid options and beforehand questions.
we know very well, that this breaks usecases - including the ones of many devs. still, we want to be delta chat an easy to use and reliable messenger, and shared usage does not go into that direction, there was just too much friction on all ends that just cost by far much many resources. we tried hard for years - and it may be “good enough for some”, but that is not our idea.
we keep it with the unix philosophy do one thing and do it right - and we voted for doing a private, reliable, easy to use messenger based on smtp/imap. this does not go well with “shared usage”. and: we do not want to be an email client.
in general, if you want to process “standard email” or “unencrypted messages” with Delta Chat - please do not. instead use a classic email client, there are quite some. on top of that, you may or may not use Delta Chat
I appreciate Delta Chat’s continued development. I understand this direction is now where the app is going, but I’m in disagreement with the removal of ‘legacy’ features. Using my existing email account and being able to bundle it with chats and have the chat contents be safely stored and searchable and archived along with the rest of my emails, as well as being able to send chat messages to other email clients without them having to sign up for a whole new account/service was the primary appeal of Delta Chat to me.
Using a dedicated account appears to add unnecessary user friction to both use cases: 1) there is now a whole 'nother email account that needs backing up and 2) email correspondence (to say nothing of fellow correspondants) is now bifurcated across email accounts and makes it more difficult, not less, to have a low friction user journey onboarding them to Delta Chat.
I have contributed zero code, zero discussions, and therefore correctly have zero expectations of any changes to the direction of the app here, but I did support Delta Chat’s vendor-agnostic approach of bringing chat UX to emails plus the nice idea of webxdc stuff, so I believe I do owe the project my thanks for what worked when we had alignment, and an honest but brief exit interview as I mentally move on from Delta Chat now.
Good luck with the rest of the project, I hope the gains pan out and the ROI is worth the pain, I’ll watch from a distance here and there.
The good thing with the way delta chat works is that there is no box to backup, because the backup is in your device.
I think rather than deltachat using the account, the real added value is in using the existing email address as a public identifier. To onboard people and tell them “you can use your existing account”, here’s what you can do today:
  • create a standard chatmail profile, have your peers do the same. There is nothing easier: open the app, create profile, put your name, done
  • Tell others to send their profile link over email. This is where dc could help
  • Open the person through the link
  • Chat with your chatmail profile. No messages are exchanged over classic emails, no confusion, no encryption degradation
It does conflict with its default mode of dc, because dc is safe from spam by default and this feature decreases safety. But it could be useful for it to automatize sending just an email with the contact info, and reading only those emails.
please don’t promote Delta Chat to people saying “you can use your own email address”, this does us more harm than helping, using Delta Chat with your classic email account (often gmail and the like) for chatting is bound to just cause a bad image of the app for them, because it is slower, it lacks push notifications, it has rate limits, they get spam, etc.
Yes, just saying “with your own email” is not enough. I will say “you can use it as an email client but can’t mix that with standard messenger use” from now on
if anything, better say “one can use a classic email as a relay”. and to be clear “one cannot mix that usage with using a classic email app at the same time”
please do not say “you can use it as an email client” - this is not supported and the - deeply hidden - option exist only to give existing users time to adapt.
similar to signal dropping support for cleartext SMS in 2022, we eventually aim to go for “end-end encrypted, always”
if one aims to use Delta Chat as an email client, better use an email client - k9, thunderbird, fairmail, claws - there are so many
when talking with others, new users, about Delta Chat, best is to not mention E-Mxxx at all :slight_smile:
we’re using IMAP/SMTP similar to other messengers using HTTPS - and one would also not think about them being “web browsers”. reason for IMAP/SMTP is decentralisation, simplicity and reliability, in case someone asks.
No mail client is as usable in practice as deltachat though, so it’s still better for me. Also when I need to send an email dc knows it’s not a chatmail account and has the “send new email” button, where I can choose recipients and all: is that also expected to be removed ? That’s the extent of what I need.
I see I was right. EEE, we call that. Now it’s clear to me that I should forget about email at all, 'cause it’s gonna be extinguished and instead focus on what DC is today - yet another e2ee decentralized IM (decentralized in hopefully more reliable way than Element, XMPP, Tox, SimpleX and friends), plus XDC. Out of curiosity, is it the project that some day changed the direction, or was e-mail designed to be only an initial attractor right from the beginning?
Dear developers, what are you gonna do with DC now, that you are free of restrictions of internet standards and backwards compatibility, and can do whatever you want with your Chatmail core library? What is your vision of the future?
was there ever an official announcement notifying those users of the need to adapt? when/where?
I also share @anendroid’s curiosity.
