Question about groups and relay changes
I’m wondering if a relay change is only transmitted to contacts once or repeatedly over a certain period. If the information is only transmitted once and the old relay becomes invalid, what happens if group members don’t check their messages for an extended period and their relay deletes them as a result? Could this cause problems with group synchronization if they later send messages in the group again?
The list of relays is sent in the Autocrypt key.
The key is sent in each outgoing message. In groups the keys of all members are gossiped periodically in Autocrypt-Gossip headers, so even if someone does not write to the group, as long as someone active in the group learns about the new relay list, they will tell about it to everyone else.
Also when the list of relay list changes, Delta Chat sends “key update” messages to contacts, so it is very unlikely that the contacts will learn about new relays. Most will learn about the new relay list from the key updates, and if this fails e.g. because someone was offline for a long time, they will eventually learn from your messages of from gossip.
