Hi there, I was really surprised today to see the app that I just released on chatmail.at. I’m flattered and grateful for the visibility. If you have any questions, let me know.
Several relays per profile. You can add more relays (transports) to a profile and see how each one is doing under “Storage and connectivity”. (Thanks to broncheolus for testing this one!)
Piirit can now be the first device in a multi-device setup.
Quick actions on the app cover. My personal favourite. You can put one or two actions on the cover, like search or opening a certain chat.
Voice calls (experimental). You can place, answer and end one-to-one calls. They’re off by default. To try them, go to Settings → Advanced. They do work - but since Sailfish OS does not come with a Calls API accessible to regular Store apps, the UX is still a bit… odd and not to my liking. Hidden behind the experimental flag on purpose, lots of polishing (and nagging Jolla) left to do.
Voice messages are sent as MP3 instead of FLAC, so they’re much smaller.
Blocking contacts works better.
Attachments are saved to Downloads/Piirit by default.
You can select and copy part of a long message.
The RPM is smaller.
As promised, I went through the English and German strings by hand and also removed most menu subtitles. The other languages were updated from that. (Thanks to frankps for suggestions for Bokmål!)
Updated Delta Chat core (deltachat-rpc-server) to 2.62.0.
To install, download harbour-piirit-2.0.0-1.aarch64.rpm from the release page and run:
Yup, first thing I tried, but in my testing deltachat-ios recipients show these only as audio/ogg file attachments, not as voice messages. deltachat-android works fine.
Decided to do what the desktop client does: WAV (temp) → MP3.
Piirit 2.1.0 is out! (Can’t post the link, see link in this post instead.)
What’s new:
Unread filter: the chat list now has Search and Unread pills at the top. Unread shows only chats with unread messages.
Any emoji as a reaction: react with any emoji, not just the quick selection. Emoji are drawn as Twemoji, in messages too.
Easier onboarding: a new profile picks a relay automatically and adds more in the background. If you want a specific relay, it’s under Advanced. Scanning a relay’s QR code now offers to add that relay to your profile.
Chat descriptions: show and edit the description of a group or channel.
Other changes:
Text written by the Delta Chat core itself (system messages and the like) is now translated into every language.
Relay list synced with chatmail.at/relays.
Turning on an experimental feature asks/warns first.
A large attachment gets a warning instead of being refused.
Chat-list ages keep moving instead of freezing at “now”.
The QR scanner no longer re-locks its focus every couple of seconds.
Avatars on the app cover no longer break.
To install, grab the aarch64 RPM from the release page and run:
Integrated video compression to make sending video more successful more often. If a video is close to the relay’s recommended size it is made smaller as soon as it is picked. You can cancel this if you want to try sending the original video instead.
Reproducible builds. Each release RPM from this one on rebuilds from its tag to the same file, byte for byte. scripts/verify-release.sh checks a release for you (docs/VERIFYING.md).
Also new or improved
Better UI/UX for QR scanner, now including torch and pinch-to-zoom
deltachat-rpc-server updated to 2.65.0
Tap a contact’s or group’s picture to see it full screen
Ringing plays the ringtone and pauses music
A call rings through the lock screen
Voice calls use the earpiece, video calls the loudspeaker
Cover shows the ongoing call
More emoji are drawn as Twemoji
An emoji at the start of a message no longer shows twice
Cover faces no longer turn into white squares
Faster all round
Hang and crash fixes
Limitations
Voice and audio calls are still limited by the lack of a calls API on Sailfish OS. Calls imitate, but don’t use the native calls UI. This also means that you need to unlock your phone before you can see who is calling and answer the call. Calls will also not show up in the phone app’s call log.
Video handling, both for attachment compression and for video calls, is done by x264, statically compiled into Piirit. It uses NEON for acceleration on aarch64 and performance is good enough, but my very uninformed gut feeling is that a better quality to power draw ratio would be possible with better platform support.
You will find that video compression is fairly aggressive. I tested a range of settings and ended up with this one as the best trade-off. The goal was to reduce the likelihood of failed message delivery, at the slight expense of video quality.
Building this took a lot of time and effort over the course of the last 2+ weeks, and I hope it will bring you as much joy as I had building it.
TL;DR: transcription of voice messages , channels, location sharing, and a tidier app all round . Below are the release notes from GitHub.
If I was to give this cycle a motto, it’d be ‘Just one more feature, then I’ll do the release!’. Reworking the UI/UX to accomodate the new (and future) features without overwhelming users took much longer than anticipated.
What’s new
Voice message transcription (experimental): done on the phone itself, in 13 languages (#286). The text shows under the message, in the chat list (#290), in notifications (#291), and can be searched (#289). I wanted this one myself for a long time .
Share your location (experimental): once or live for up to 24 hours, with a map per chat and one for all chats (#259).
Channels: join one by QR code or invite link, or make your own (#211).
Settings UI/UX cleanup: with more features in the app, settings grew busy. Now they are a bit tidier again(#305).
Contact and group pages UI/UX cleanup: same as for settings. Theses needed a new layout: picture beside the name, members as one row with a searchable list, and a new Encryption info page (#303), chats in common (#209), shared header band (#310).
Notifications per chat: turn them off for 1 hour up to 7 days or for good (#210), now a page with the time left shown (#303).
Chat list filters: Chats and Channels buttons beside Unread (#293), and Archived, moved there from the pull-down menu (#311).
Replies: a tap on a quote jumps to the quoted message, even in another chat (#208).
Other changes
Emoji are sharp at every size (#220), show as pictures in names (#216), leave more room beside words (#267), and a message of up to five emoji shows them big (#213).
Avatars: an emoji at the start of a chat name become that chat’s picture (#252).
Search results highlight the searched characters in bold (#215).
Optional profile picture and name in the chat list’s corner (#308). The Search button shrinks to its icon when space is tight (#306).
New (#211) and Add profile (#224): proper Silica dialog to pick what to create.
Faster: opening long chats, scrolling, big groups, the emoji picker, the camera, and catching up after being offline (#284).
Piirit notices when the Delta Chat core stops and restarts it (#300).
Fixes: notification taps doing nothing after switching profiles and a double photo on a second shutter tap (#284), blank chat on return (#217), “Delete messages from device” resetting to Never (#200), people missing from the cover (#272), a setting changed twice quickly keeping the first choice (#232), “No chats yet” flashing when Unread is turned off (#230), swiping back reopening a finished backup page (#207), the Mentions setting’s description (#218).
Delta Chat core (deltachat-rpc-server) updated multiple times. Was 2.65.0, is now 2.69.0 (#258, #292, #307).
Limitations
Below are only the ones that annoy me the most. A longer list can be found here.
Voice and video calls still have more lag than I would like.
Voice-to-text is all done on-device, with a small model (about 190 MB). Expect some mistakes, in some languages more than in others. Some languages are disabled to avoid disappointing/annoying users.
UI/UX is still way too clumsy when sharing location and e.g. compressing a video attachment at the same time. MOAR polish!
App is still portrait mode only.
PDF attachments (and non-media documents in general) don’t show a thumbnail and often don’t open properly in separate app.
