Permanent SMTP error: permanent 5.5.2
Hallo,
auf einem Iphone funktionierendes Profil wurde mit der klassischen Methode zu einem Windows 11 Desktop übertragen.
Deltachat lässt sich dort öffnen, aber es werden keine Nachrichten versendet oder empfangen.
Es erscheint die Fehlermeldung:
“Error: Permanent SMTP error: permanent: 5.5.2
<[2a02:908:1e4:b920::d250]>Helo command rejected: invalid ip address
Message-ID:; Mr. TdWT4SU6MJ-.PcnhKe2IraN@localhost
No hop Info”
Kann jemand helfen?
Dirk
Error “invalid ip address” is generated by Postfix check “reject_invalid_helo_hostname”. Delta Chat sends [127.0.0.1] as the HELO hostname which passes this check, so this cannot be a rejection from Postfix smtpd that Delta Chat connects to:
Probably Postfix fails to send message further.
Many thanks for your answer.
Curiosly the error exits since adding a new profile with the team managed mail server nine.testrun.org.
A formerly created profile on the same PC with mail server mail.de works fine. So it looks like the new profile or the mailserver is reasonable for the error message.
But I do not know a way to fix.
I had a similar problem trying to config Neomutt to use a chatmail address (to load the public key of a correspondent into a Deltachat client; a kludge).
Neomutt could download mails but not send them. I got this message:
msmtp: server message: 504 5.5.2
: Helo command
rejected: need fully-qualified
hostname
msmtp: could not send mail
(account
xxxxxxxx@nine.testrun.org from
/home/mobian/.msmtprc)
I’ll post any progress, comments welcome.
I added
domain 127.0.0.1
to ~/.msmtprc
Result is that sending hangs forever, then:
msmtp: recipient address
xxxxxxxx@nine.testrun.org not
accepted by the server
<127.0.0.1>: Helo command
hostname
(account
So this is maybe unrelated. Suggestions, ideas?
It should be domain [127.0.0.1] instead of domain 127.0.0.1. This is also what Delta Chat sends in EHLO.
Vielen Dank, so einfach war’s! Offensichtlich sind Klammern mir unsichtbar.
Jezt muss ich nur noch hinkriegen, dass die Mails von Mutt als verschlusselt beim Server erkannt sind…
