Make sharing channels easier
I’d like sharing a channel to work similarly to sharing a contact: tap the three-dot menu, then tap Share.
To prevent private channels from being shared too easily, a toggle can be introduced in the UI stating something like *Automatically share the invite link through the channel description* or *Let your readers share the channel on your behalf*. The text should make clear what it does and maybe even a link to the docs about channels. Depending on the setting, it could enable a Share button or automatically add, remove, or update an invite link in the description.
Right now I can’t find an easy way to share channels without having to contact the owner of the channel asking for its invite link if I lose that link or it has been invalidated for some reason.
What do you think about it? Have I missed something important?
yip, this is something we want to improve.
it should be also possible for a subscriber to show an QR invite code to someone else. this is esp. needed as the private channels of delta chat have no global discovery.
today, as a workaround, channel owners can already work around that by adding a QR invite code to the channel description or post it from time to time to the channel, maybe together with a QR code. i have seen that several times
