Home Assistant integration for sending notifications via Delta Chat
Hi all,
I wanted my Home Assistant notifications to come in over Delta Chat, so I made an integration for it: GitHub - mariogrip/home_assistant_deltachat: Home Assistant integration that sends notifications over Delta Chat (HACS) · GitHub
It’s inspired by MichaelBitard’s work on a Delta Chat integration for Home Assistant core, which I turned into a custom integration you can install through HACS. A lot of it ended up being rewritten along the way.
When you set it up, it creates a bot account on a chatmail relay (nine.testrun.org by default) and shows the bot’s invite QR code. You scan that in Delta Chat, and then pick the people who joined as recipients. Each recipient becomes a notify entity in Home Assistant, so you can use it from automations like this:
action: notify.send_message
target:
  entity_id: notify.delta_chat_alice
data:
  title: Front door
  message: The front door was opened
The bot keeps running in the background (deltachat-rpc-server through deltachat2), so it can handle the secure join and tell whether a message was delivered.
To install it, add the repo as a custom repository in HACS for now. I have a PR open to get it into the default HACS list. It needs Home Assistant 2025.3 or newer.
For now it only sends messages, so anything you write to the bot is ignored. Letting it receive commands could be a next step if anyone wants that.
It’s still early, so let me know if something doesn’t work, either here or on GitHub.
