Two nerds ditching Signal for almost 3 month in favor of DeltaChat as an experiment. We’ve been using the nine testrun org relay server. We wrote this feedback in June 2026, and we’re still using it as a daily driver now (October 2026). We figured we would share this here, and maybe later split it into dedicated feature requests. First off, thank you for this amazing project!
So far so good. What we really liked:
Client customization (background, avatar, dark mode)
DeltaChat technology
Very responsive, no perceptible delay in messaging
The internal apps are very easy to install, although didn’t use so much after a try or two.
(Good) Native clients on desktop, android and ubuntu touch
Friction points:
On default desktop client, pressing [enter] should default to sending, not new line (like in most other apps)
Slow synchronization between clients: messages are sequentially downloaded without any progress indication, sometimes triggering new-old notifications (when syncing after many messages between two syncs, barely noticeable when the delta is smaller)
QR code did not work for one of us, having to rely on the backup import feature (which worked flawlessly)
We experienced in rare cases a big delay between a message being sent and being received. Could be a network/client/user issue tho. (Delay of many hours)
Android randomly decided to power-limit DeltaChat, making one of us missing many messages. (Not your fault we concede!)
Pain points:
Can’t edit images before sending them
You can’t get a preview of the links you send (special case for GIFS).
Improvements:
Square for Apps & Media is confusing : as users, we thought this would be a button to install more Apps, not to access the different kind of media. Maybe change the icon to a media icon, and either add a separate button for the apps collection, or have the user first see the images first, apps should be the last section.
When you modify a message that has a reply to it, the original message is modified, but not the quoted message.
If technically possible, a warning message regarding android power saving/optimization being enabled for the app would be great
Features requests:
Allow for a custom background per conversation instead of one for the whole client
Allow for quick reaction emojis to be either customized or based on the most used ones
Add the possibility to enter and pick emojis through a text shortcut “
” for example, instead of having to go to the emojis menu every time. -
Allow for automatic backups (would be even more wonderful to support cloud storage!)
Overall we’re using DeltaChat for our daily conversation instead of Signal without really thinking about it. It just works and most improvements and pain points are either due to our habits with other apps or QOL little things.
