Enabling system side emojis it blocks the possibility to use the entry button in default AOSP keyboard
As I said, If I enable it, that blocks me the possibility to use the entry button in the keyboard because it’s replaced with the emoji button. I am not sure if it’s just a problem with the keyboard but AOSP keyboard which is always without maintenance and it would be great solve it from Delta Chat side and I found an option.
By default, with emoji button in entry box by default, I could use the entry button and pushing it a moment I can use emojis from keyboard.
Some screenshots,
Option disabled:
Option enabled:
Note: In both cases I am pressing both entry and emoji button on the keyboard to show the possibility.
yip, you’re right. this is weird, i’ve created an issue for this at https://github.com/deltachat/deltachat-android/issues/1015
fixed at allow multi-line-messages when system-emojis are enabled by r10s · Pull Request #1016 · deltachat/deltachat-android · GitHub :slight_smile:
I forgot the issue after using the first option showed in the screenshots until @Simon remembered to me with Android Emoji button missing
Can I mark this topic as solved? or should I wait to check the changes in the new release?
i think it can be marked as solved, the fix will be part of the next release then.
