Delta Chat posters
here you have some Delta Chat posters to help you promote Delta Chat and convince your family and friends to install it. The usefulness for kids is a strong point that usually helps a lot to make the family migrate!
If you could share the sources in editable format I would be happy to translate them into Italian.
here you have 3 of them that have GIMP project you can edit:
WARNING: the link will expire in 24 hours!
missing the “save chat for kids” one
as said, that are the ones that had a GIMP project, but here you have one about “save chat for kids” topic: Wormhole - Simple, private file sharing
Copyediting nitpick:
“Express securely” should be “Express yourself securely” or “Express your views securely” or something, because “express” is a transitive verb. And “accross” should have only one “c”.
I like the “Reliable”. So many apps break when some people upgrade. If the upgrade availability on different platforms is not synchronised it’s a nightmare.
Maybe add “, standards-based” after the “open-souce” (which might be better hyphenated, as not just the source is free)? Both “Private. Decentralized. Yours.” lines need that final full stop.
great posters! very useful material! thanks a lot :heart:
even if i would not recommend start replacing other messengers alltogether first - better start with some friends and family willing to switch for some chats - the following may be handy as it is so easy to get :slight_smile:
Was going To reply to this but reply may be better in the Show and Tell section
and another one, seen at RaphM ⏚: "Alors j'ai essayé de résumer graphiquement ma log…" - Mamot - Le Mastodon de La Quadrature du Net, for the french will-be Delta Chat users:
Found on Mastodon
and another one, from Leander Lindahl: "Use the opportunity to switch to a European messe…" - Folkdata Mastodon
English
Spanish
The correct spelling is video calls.
i already asked ai to translate them into chinese (without watermark) & send them to the social media!
