Delta chat portable also move DeltaChatData folder?
windows 10 professional
Double clicking DeltaChat-Portable-v1.0.0
creates a folder named
DeltaChatData.
If you want to move delta chat to another computer, then
you have to move both the
DeltaChat-Portable-v1.0.0 file
and
DeltaChatData folder? Thank you.
Yes you should move the DeltaChat-Portable-v1.0.0.exe and DeltaChatData folder. It’s important that the .exe is next to the DeltaChatData folder. If you want to upgrade DeltaChat, you can just put a newer portable version there and it should work.
