Client send mails put not reciving with proton mail
Last Version
The client send emails put don’t receive them it keeps saying connecting i disabled firewall tried changing ports etc no use
Proton mail needs its own app.
Are you using ProtonMail Bridge?
Yes I know as I said sending mails working fine but I am not able to get mails back (replays ) I use the app correctly I am sure do you have delta chat work with proton mail ?
Yes I do as I said sending mails working fine but I am not able to get mails back (replays )
Could you PM me the log or publish it here after removing details (login, email addresses etc.) from it? IMAP should be configured to 127.0.0.1, port 1143 according to ProtonMail documentation:
Users have successfully configured ProtonMail Bridge previously, but note that ProtonMail Bridge had an issue with Autocrypt headers on the receiver side: ProtonMail bridge strips Autocrypt headers · Issue #186 · ProtonMail/proton-bridge · GitHub
If the issue is not fixed, then Delta Chat will think all your contacts don’t prefer encryption and will not receive their keys.
2
3
4
Please note smtp works well sending well only receive I checked ports change ports even disabled firewall no use receive dont work
I sent them
Why the port is 1144? Documentation says it should be 1143
